catalytic deleted
2007 gmc Denali with cold air-intake and catalytic deleted worth to tune it ?
I am using Hp tuners what to change and what tablet is the one to look for also is it possible to tune my truck to make pooping and make backfire or am just asking to much , I have coldairintake and cat deleted , and what table to modify am sorry am just new to hp tuning , thanks every one MJ |
Yes it needs to be tune to stop the computer from throwing codes and enabling the CAT diag tests on you.
There is a COT (cat over temp) that you need to disable under the Engine > Fuel > CAT/DFCO tab. Under Engine Diag > Exhaust there is a Post o2 sensor test and a cat converter test itself that you need to disable. Then you need to disable all Bank 1 sensor 2 and Bank 2 sensor 2 codes. Change them all from 2 MIL on Second Error to 3 No error reported. |
FFDP , thank you for the Help
