Can the ecm support 2 obd 2 ports?
Old 05-12-2018, 12:49 PM
crashmymax's Avatar
Default Can the ecm support 2 obd 2 ports?
I use a dash logic for my gauges which connects directly to the obd port. I want to be able to run my dash logic while scanning with hp tuners. I already tried a splitter but both cannot run at the same time. Is this because the ecm cant support both? If I ran a full set of second wires to a second obd port would it make any difference?
Old 05-12-2018, 02:54 PM
Littlefield's Avatar
I tried a splitter with my Aeroforcetech gauge and MPVI Pro. Worked one time out of about five. The scanner would lose track of the truck E92 supported PID’s and I’d have to disconnect, reboot and connect back the HP to get them to reload.
Old 05-13-2018, 02:41 AM
Mod with training wheels
smokeshow's Avatar
I'm no CAN expert, but...it depends on whether or not the dash logic is interrogating one or more modules while it is connected. There are certain messages called 'legislative PIDs' that the government requires to be transmitted on the CAN and available for reading by any old scan tool. If you're selecting PIDs in HP Tuners, you'll notice these as the green highlighted PIDs. Obtaining any other information requires interrogating a module and occupies the communication channel, so only one interrogation session at a time is permitted. Same reason why writing a file in HPT fails when the scanner is still connected. It sounds like the dash logic is interrogating modules on CAN, so I don't think it'll work in parallel with HPT.
Old 05-13-2018, 08:20 AM
Makes sense. Mine would log some parameters but not all.
Three6GMC
09-05-2014 12:02 PM
Three6GMC
06-30-2014 03:23 PM
blazinblue
06-17-2013 01:14 AM
YenkoST
09-11-2011 07:43 PM
BlownChevy
12-22-2006 01:09 PM
Quick Reply: Can the ecm support 2 obd 2 ports?
