Brake pedal dropping to the floor
Old 08-06-2018, 07:01 AM
The slow hoe's Avatar
Default Brake pedal dropping to the floor
I have 06 ex-trooper Tahoe I changed the calipers and pads all the way around bleed the brakes but didn't have much for a pedal. So I bleed the abs which didn't help so I changed the master cylinder and bled them all again. The brake pedal firms up a little bit when you pump it with the engine off but once you turn it on the pedal goes to floor and comes back up real slow. What do you guys think it could be its hydro boost too by the way.
Old 08-06-2018, 07:46 AM
I have a gauge for that
Atomic's Avatar
You have air in the booster system, which can happen if you force the caliper open when changing pads. Bleed the power steering system.
Old 08-06-2018, 09:27 AM
11 Second Club
MrHorsepowerLSx's Avatar
A side note on a properly operating hydroboost setup, you can rest/press your foot on the brake pedal and start the motor. The brake pedal should drop .5-.75” and then return to top of pedal, when in proper operation
Ferocity02
09-16-2016 07:33 AM
yellow2000S/R
08-24-2015 10:06 PM
95wannabe
10-07-2013 12:17 AM
Jim_PA
84
10-19-2011 10:20 PM
Jim_PA
07-22-2010 09:24 PM
Quick Reply: Brake pedal dropping to the floor
