Bondo's nanny log with ls1m
Guys, after installing Bondo's custom tune, we did a little nanny log on it with my ls1m. Here is the file we came up with. Please take a look at it and let me know what you think(I'm a total noob at the tuning thing). This was a 1/4 pass that was logged using my old crappy gtech for distance. Thanks
FWIW 99 is all I ever see for TPS when I log. Your O2s around 900mv look perfect for FI but probably a little too rich for NA. Your IATs look good and you must have a 180* stat. Timing looks about right for NA. Your LTFT look a little lean (adding fuel) at part throttle and your O2s appear to be a little on the rich side.
Be warned I am a bit of a noob myself at reading logs.
with what i see there i would add a few more degree's timing. 4 to be exact to max it out at 32 degrees. you are running lean and the computer is adding fuel. same thing my truck did with the predator tune i had. also it was stated above that it's running lean and fuel is being added. high 800's on the o2's would be nice but i wouldn't sweat low 900's. lets see what we can come up with and then log that and compare.
If you are N/A I would lean the PE up a tad.Add to your VE also,your trims are at about +4 or so so work with your VE (adding) to bring the trims down.Looks like it is + values through out most of the run,so work in the cells that are +.I always want my Ltrims from -1 -4 nothing more or less.
Also,you can put in what value you want when you want to PE to kick in,it doe snot have to be at 100%,you can set it to 85%,50% whatever you command it it to kickin,also don't forget about the PE delay.
