Blower motor 1 2 3 work not 4 5
My blower motor only works on 1, 2 and 3 but not 4 or 5. I had this problem in one of my previous silverados but I can't remember exactly what I did to fix it. I might have replaced the blower motor relay or the entire blower motor. I don't think it was the switch itself. Anybody else had this problem?
Thank you |
My guess is the blower motor resistor or wiring to it. Its attached to the bottom of the air box by the fan and can be removed with (IIRC) taking out 2-3 10mm bolts.
Originally Posted by DRAENOR
(Post 5390577)
I used to see that alot at the dealer, especially on the older GM trucks. Always sold the resistor and harness cause it usually melts the original stuff. The replacement is a better setup but all the wires are white or grey Lol. Thanks for color coding GM!! Just have to keep wires in order as you do them one by one |
yep i replaced resistor and harness in my 05
So I replaced the blower motor resistor and now I have 1, 2, 3 and now I also have 4 but 5 still doesn't work. When I turn it on 5 I hear a little click where the resistor is. Any ideas?
did you replace the harness or just the resistor?
Just the resistor but I need to do the harness too.
yes. theres prob a burnt connection inside the harness
I fixed the harness with no luck BUT I found the problem. There is a fuse under the hood for the high speed #5 blower speed that was blown. Replaced it and now everything is good.
https://cimg1.ibsrv.net/gimg/www.per...51962b8f44.jpg |
