Bad crank position sensor? HP tuners scan attached!
2 Attachment(s)
What do you guys think? I'm having problems with it idling very rough once it warms up. Watch the 'current cylinder firing' tab and notice that a lot of the cylinders do not show up. I have it set to a high frame rate so you can slow it down and watch it closely. I know sensors do not like heat, and since the crank pos. sensor is right by the turbo mani, I could see this being a likely problem.
It is also extremely slow. I ran a 14.5 in the 1/4 mile w/ my current set up! I attached the scan and config files |
The correct firing order for my engine should be 1-8-7-2-6-5-4-3
the first length of numbers from this scan show 6-7-2-4-6-0-2-5-7-1-3-5-7-1-4-6-0-3-5 and on. It seems to be just random |
| All times are GMT -5. The time now is 01:29 AM. |
