Backfire
I started my o5 silverado this morning and heard a real slight backfire. Only does it on a cold start. Still runs like a champ. What do you guys think???
Is it stock?
Airaid Cai with tb spacer , 3" dual exhaust , Wheatley performance toon , just bolt ons.
No takers??? Any ideas at all??? Maybe Ill start with plugs and wires.
Yeah miss fire is normally spark related if it's not boosted, id replace the plugs and wires, the check for weak coil, then talk to your tuner
Hmmm. Check coils? Maybe volt/amp meter or do they make a tool ? If volt/amp meter what would be specs ?
Made a vid to explain better. You can barely hear it on initial start up.
What happen. You guys are usally real good at this. You guys usally tell me the solution with just a little discription. That's y I always refer back to this site. Don't leave me hangn.
my truck had a slight hesitation and a backfire when it was cold. Its was due to a lean condition from sticky injectors.... i replaced the injectors and it runs better than ever now. you could always get the fuel system serviced or take it to a shop to get a diagnostic run on it to see whats going on.
Originally Posted by gowic
(Post 5017668)
| All times are GMT -5. The time now is 06:50 AM. |
