Edit: Justin beat me to it....
Originally Posted by dewmanshu
(Post 3865437)
I just looked at these 2. Again...not familiar with EFI
Taking another look, it seems that your WOT 1->2 shift parameters are less than your 2->1 shift parameters. I believe this confusses the computer/tranny... Attached is what your currently looks like... http://i27.photobucket.com/albums/c1...g/WOTShift.jpg |
LOL you and justin are on it now.
btw...I take back my zero'ing WOT shift speed comments. Justin has again reminded me of "error-ed" ways. There is no WOT downshift speed setting so it wouldn't help matters. |
Originally Posted by BlackGMC
(Post 3865388)
Sorry I did not notice he posted the tune... Looking at your tune your Part-Throttle shift MPH is at 56 in the last two cells (93.8% and 100%).. Given your tire size (31.86) and Gears (4.10), so that translates into 56MPH @ 6000RPM... IMO this is why your hitting the rev limiter.... Lower the last to cells in the part Throttle table by ~5 MPH, then you should be good to go!
Edit: Sorry about this, but the new version 7.5? converted all the numbers wrong when I installed the software up at work.... |
Originally Posted by dc_justin
(Post 3865481)
Couple of things I see here, although not necessarily the cause of your problem.
2-1 downshift speed is higher than upshift speed. Upshift speed should always be higher, or the shift will not be commanded until after the downshift speed has been met as well. Might try setting D0913 to 35-37mph, see if that has any effect. I thought BlackGMC had nailed. I was hoping....:gruffy: |
1 Attachment(s)
Originally Posted by 1SlowHoe
(Post 3865501)
So this info is no good anymore? (due to your computer giving you wrong values) I cant see my tune at the moment. I dont have EFI on this PC.
Partly, the numbers in the tables I was referencing were wrong but the calculation for you shift point was correct. I have attached a spreadsheet that calculates your MPH vs RPM vs Gear for both the 60 and 80 trannies... I use it for calculating my shift points, hopefully you have excel, if not I will post up a pic of the numbers... |
(Post 3865503)
(Post 3865515)
Sorry, bad install of EFI Live on my work computer... You should see what loggs look like on it...
My Advice = http://smiliesftw.com/x/spillbeer.gif
(Post 3865509)
(Post 3865537)
Cool. Thanks. I have Excel. What table in EFI were you pulling values from for that calc?
