4.8 5.3 swap wiring issue and reduce engine power
Old 08-07-2018, 08:28 PM
Registered User
Brandon Wright's Avatar
Default 4.8 5.3 swap wiring issue and reduce engine power
I recently purchased a 2004 Chevy Silverado 1500. I only paid $250 cash. I tried buying the truck years ago. The truck originally had a 4.8 vortec. The guy swapped it with a 5.3 vortec. He did a body mount on the truck my guess it wouldn’t fit in length he cut the wires then re splitched all the wires. Witch would be why it says reduced engine power when ever I hit the gas pedal nothing. So he then changed the pedal and sensor because it has a drive by wire throttle body. That didn’t work so he then cut the wires to the throttle body. I can see the connector don’t even fit. When I hit the high beams it shuts my truck off and I don’t have half the power to the fuse box. My question is Idk what year motor that 5.3 is I’m pretty positive it’s a 2004 motor but if not how do I find out the year of the motor ? I have been trying to find a complete harness on eBay for the truck interior and engine harness. All I see are painless wiring kits or places that re wire and glacé the pcm. I really wanna have the pcm flashed anyways what would y’all do? I DO NOT WANT TO GO TO A JUNK YARD! I work 15 hour days rather order it and put it on my self.
Old 08-08-2018, 04:49 AM
madmann26's Avatar
Let's start here,
Is it DBC or DBW? (drive by cable or drive by wire)
Old 08-08-2018, 12:01 PM
100% Redneck
RedXray's Avatar
Received 1,329 Likes on 792 Posts
A few ebay searching tips:
It's easier using a PC instead of a mobile device
click on the "used" condition tab to weed out the hits
you are looking for a 03 to 06 engine harness (if you have DBW) using search key words "Silverado engine wiring harness" then add in "tahoe" "yukon" "escalade" "suburban" and "sierra engine wiring harness"
make sure the engine harness matches your transmission type 4L60 or 4L80
In two minutes I found this harness but It doesn't have the trans type listed so the seller must be messaged EBAY LINK
The engine date code is cast into the engine block in front of bank 2 (pass) cylinder head with four letters & digits
Here is my 2005 LQ9 6.0 engine date code (K134) "November 13th 2004"
4.8 5.3 swap wiring issue and reduce engine power-uiof2vf.jpg.
Old 08-08-2018, 02:03 PM
Registered User
Default Bought a harness
So I found another 2004 Chevy Silverado. I purchased the under dash harness and the 5.3 engine harness and the 4l60 trans. It does have a drive by wire throttle body. I’m just buying the harness no pcm gonna re use the orginal pcm. Gonna change the location of the ground and buy a new throttle body and pedal and model. Do I have to have the pcm re flashed for vats. Even tho I’m reusing the original pcm.
Old 08-08-2018, 02:05 PM
Registered User
Also I’m buying a new fuse box for the cab and the engine. Just want to know if ima come across any promblems installing this new harness.
Old 08-08-2018, 02:16 PM
100% Redneck
RedXray's Avatar
No re-flash necessary
Just curious why change the (three) engine harness ground locations? The top two are doable with the intake removed, you cant see much but if you know where the bolt holes are you can feel them out. Just did an engine swap and those two top grounds took about 15 minutes.
Old 08-08-2018, 03:57 PM
Registered User
I want to change the grounds because the guy cut every wire to the harness when he did the body lift. He put all the grounds on one side under the cab. It is giving me the reduced engine power. I read on forums if the ground isn’t in a good place the reduce engine will come up. I’m worried that since the body lift wasn’t bolted down right with the cab moving a lil when it runs the ground ain’t gonna be secured right. I rather it be done and me be able to get access to the ground cables to cause I’m gonna take the body lift off and do a air bag lift kit or a shock and coil lift kit I don’t like how he made the body lift he made it him self and it’s all messed up.
Old 08-08-2018, 04:01 PM
Registered User
Money ain’t a issue I just want the truck to be reliable! I only have 800 into the truck with having it towed buying it and buying both the engine and under dash harness. That’s why I’m buying the throttle position sensor and the throttle body that way I know for a fact everything this moron did is fixed. I work 16 hours a day and only have one day a week to work on the truck. I want to have everything ready to go on my day off so I know if I come across any promblems I have the parts to put on. I tried 4 years to buy this truck I want it done right and soon so I can have it painted
Old 08-09-2018, 07:15 PM
1994Vmax's Avatar
Why I have never looked at that code before is beyond me and that is handy for sure. Fun fact, my LQ9 I have had sitting forever out of an 05 Escalade is K144 lol. Looks like they were cast one day apart haha. Nice to know the engine in my turbo'd Nova is an 06 cast block... confirms my suspicion it's an engine with good rods so I don't feel bad boosting it to an ungodly level.
Flaco
05-30-2008 09:19 PM
Biggin
02-14-2008 10:17 PM
gmcC3syclone
02-07-2008 10:24 PM
gmcC3syclone
01-31-2008 12:02 PM
gmcC3syclone
12-31-2006 07:47 PM
Quick Reply: 4.8 5.3 swap wiring issue and reduce engine power
