Wideband all over and odd readings
Old 06-16-2018, 11:09 PM
regency's Avatar
Default Wideband all over and odd readings
So tonight driving around after swapping bad O2’s i noticed with cruise on the afr was constantly bouncing from 13.4ish to 15.2ish also a pretty steady misfire type noise in the exhaust tone and when i would just roll into the throtte afr would just climb to 18. Didnt have HPT to log this, but i need to watch the new O2’s and verify they are working correctly first off. But other than that, what else should i look at?
Im thinking maybe i should pull the plugs. What about injectors? Wouldnt this be a sign of a possible faulty injector?
I do not have another sensor to check against my current sensor for wideband.
Old 06-18-2018, 10:09 AM
I have a gauge for that
Atomic's Avatar
Cruise AFR is normal. Misfire could be anything but its usually plugs or ignition related. What mods do you have? Rolling into it and going lean is bad, either needs tuning or fuel pump probably. The O2s will show lean as well if it actually is.
black04
01-27-2011 08:04 PM
spinz71
11
11-27-2006 09:28 AM
Flyer
04-20-2004 03:40 AM
jlwz71
11-19-2002 08:47 AM
Quick Reply: Wideband all over and odd readings
