2017 Sierra 6.2L Maggie TVS1900 Tune
Thanks for the spark plug suggestion.
Actual TVS1900 straight from Magnuson.
Thank you for the info!
What would happen if I ran 3-5 gallons of E85 and then the rest (17-15 gallons) of 91 octane?
Would this damage the truck or supercharger at all, given the truck is not E85 compatible?
No and if there is too much Ethanol in the gas it lights off too quick.
Race gas does not contain ethanol. By adding a higher octane. Say a few gallons It would increase the octane rating. The truck should smooth out.
Water/methanol is used to cool the intake charge under power. It helps keep the cylinder temps down while maximising power.
Had a similiar issue and my converter was going out and causing excessive load at part and mid throttle ; almost like if you tried to floor it in 6th gear and never downshifted. The tranny was trying to compensate and thus ping ping ping a low-med load while cruising.
You need to pull back timing until you figure this out if you are going to drive it btw.
changing plugs would be a good start too, gap them a bit smaller. .035 i think.
If I were to switch to new spark plugs, which ones should I get? Brisk said to get their RR14YS (two steps colder, .028 gap, projected tip). Also looks like the NGK BR6EF-3177 might be good (one step colder, .028 gap, non projected tip). Or the NGK BR7EF-3346 (two steps colder, .028 gap, non projected tip). I was thinking of switching and not just closing the gap on my stock plugs because of being told to go colder on the heat range. And do I do a projected tip or non projected tip?
I'm running a Maggie TVS1900 with stock pulley and boost (only about 6-8 PSI I assume) on a 6.2L Everything else is stock. I seem to be pinging just a little bit still while getting into heavy load (and then it goes away quickly) even after pulling quite a bit of timing. This is on crap California 91 octane.
