2012 Gmc Sierra how to do the 6 hi mod
Old 05-20-2012, 04:17 PM
01 PONTIAC WS6's Avatar
Default 2012 Gmc Sierra how to do the 6 hi mod
Hi guys does any one now how to get the fog lights to turn on with the DRL and how keep the fogs on when I turn the highs lights on THANKS.
Old 05-20-2012, 04:34 PM
iamkeniff's Avatar
DRL is its own system basically. You dont want to have fog lights running 24/7.
As for the 6Hi mod you use a resistor to jump from the high relay to the fog light fuse
Old 05-20-2012, 05:52 PM
Want kind of resistor do i use
Old 05-27-2012, 05:51 PM
LS3SSRS's Avatar
i used a diode from the source/radio shack.. 2pack for a couple bucks. drivers side, under the dash is a stack of plugs. grey, pink, orange, then black. unplug the black one, fish it down, and wire the diode between the peach/white and green/white wire. the striped side of the diode wires to the peach/white wire. plug it back in, all lights on!
Old 04-28-2013, 08:33 AM
Truckshop's Avatar
Pink/white wire from the brown connector hooked to the green/white wire on the black connector on with a diode. Both connectors side by side on the bcm. Will make the figs stay on with the lows. Stripped side of the diode to the pink/white wire.
I know this is old but its the best info I could find when trying to hook mine up yesterday.
GXPJAY
02-13-2022 08:15 AM
markyrgv
08-16-2015 11:50 PM
lawhitediamante
08-12-2015 12:14 PM
GMCSIERRA5.3
08-07-2015 01:50 AM
Jake75
07-22-2015 09:20 PM
Quick Reply: 2012 Gmc Sierra how to do the 6 hi mod
