05 Silverado Twin Turbo 4.8 Tuning help
Hi guys hopefully someone can give me a hand with a tune since i have just built this car with the following parts...
2005 Silverado 4.8 single cab
(4l60) stage2
Steel stock drive shaft
3:23 axle gears
Twin 7268 turbos
Twin Walbro 450s 8an feed 6an return 1 is with hobb switch that activates on 4psi
Fuel pressure regulator 1:1
Deka 80s injectors
BTR Stage 1 twin turbo cam
BTR dual Springs
BTR Trunnion Kit
BtR hardened pushrods
Melling high flow high pressure oil pump
Front mount intercooler
Ls9 head gasket
Ls7 lifters
Ls2 timing chain
NGK BR7EF spark plugs
NGK spark plugs coils
MSD 2step
ARP Cylinder head bolts
Water/Meth dual injection port
Speed density IAT sensor
GM brick 3 bar map sensor
2800-3200 torque converter
Hp tuners pro.
Aem wide band for both Banks
oem o2 sesnors for both banks sensors 1
no rear o2 sensors
purge control valve deleted p0443
93octane fuel with meth injection 50/50
heres my Log and TUne i have im trying to learn more thanks and a pic of my build thanks
Sage G
16
02-28-2018 07:43 AM
Yelo
01-30-2009 09:40 PM
