03 Dash lite problem
The Dash lites and Radio/A/C cluster lights stay On, though I can dim them with the Dimmer on the Headlight switch. I unplug the headlight switch and everything works normally, Until I press on the brake pedal. Then the dash lights are back on ?
Possible Headlight switch ? All fuses are ok.
Been there seen that as Mice or ? chewed on the Cruise enable wire... ]
In disconnecting the Headlight switch again, I can get the dash lights to reset sometimes, not all the time. I seen that with the headlight switch Disconnected, the Dash/Radio lights are always ON. Also when turning off Key, Radio is still on no matter if dimmer has Dash lights dimmed or not ?
It was a 2003 2500 I had the problem on, it always drained battery over a couple hrs, then a no start happened, realized dash was staying on along with a lot of other components- when finally finding the issue the headlights would stay on also when connecting the battery. Basically everything came on without the key in the ignition
fuse box was $5xx from dealer
on the underside of it, was corrosion on all the terminals (sorry nest was under the box, not just under the cover, sorry for confusion)
