Wts/wtt 01 silverado procharged t56 swapped
2001 Chevy Silverado Extended Cab 2wd has the 5.3L/T56 (6 Speed Manual) combo. Has 98k original miles on it and like 112k on the cluster. Still have original cluster to prove and less than a 4000 miles since the cluster swap. Cluster was swapped when truck was an automatic to have the factory trans temp gauge and the cluster can be swapped back for the original if owner prefers. Truck has all power options . Truck thousands of dollars in extra parts and only the best stuff was used. Cannot stress enough how solid this truck is and how well built it is!!!!!!!!!!!!! Listed below are things added to the truck that I can think of probably missing somethings. Truck has been dyno-tuned at Sho-Me Speed in Springfield, MO put down 442/440 @ 8 psi on the dyno. Truck is located near the Arkansas/Missouri Line. Asking $14,000 OBO, if interested can call/text Chris @ 479-five eight six-3732
Engine:
5.3L Vortec V8
Comp 275HR Cam
PAC 1218 Springs
Comp Magnum 7.4 Hardened Push Rods
Procharger P1SC Currently Set @ 8-10 lbs of Boost
Front Mount Intercooler
42 lb. Delphi Injectors
Walbro 255 In-tank Fuel Pump
LS1 E-Fans with Harness
Stainless Long Tube Headers & Stainless Y-Pipe
QTP Electric Cut-Out
Borla ProXS Exhaust
Smoothed & Painted Vortec 3 Piece Engine Covers
Transmission:
Tick Stage 2 T56 (6 Speed)
Monster Stage 3 Clutch
Monster Billet Steel Flywheel
MGW Short Throw Shifter
Suspension & Rear End:
Full DJM 4/6 Lowering Kit & C-Notch
Belltech Street & Performance Shocks
Drilled and Slotted Rotors & Pads
Russell Stainless Steel Brake Lines
4.88 Gears
Yukon Duragrip LSD
Perfect Launch Diff. Cover
Caltrac Traction Bars
Exterior:
Fresh Paint
Full HD Front End (Hood, Grille, Bumper Cap)
All Colormatched (Bumpers, Mirrors, Handles)
Bed has Shaved Stake Pockets & Molded Rollpan
Shaved Tailgate
Smoked 03-06 Silverado Tail Lights
Clear Headlights/Parklights
All LED Exterior Lights with Switchback LED in Turn Signals
HID Hi/Lo/Fogs
Billet Grille & Billet Emblem
Tahoe 20s with New Tires
Interior:
Full Katzkin Leather Seats
03-06 Tahoe Center Console
All LED Interior
HD Cluster w/Trans Temp Gauge
Autometer Wideband Gauge
Autometer Fuel Pressure Gauge
Autometer Boost Gauge
Panasonic Double Din Stereo
Engine:
5.3L Vortec V8
Comp 275HR Cam
PAC 1218 Springs
Borla ProXS Exhaust
Transmission:
4.88 Gears
Yukon Duragrip LSD
Exterior:
Fresh Paint
Shaved Tailgate
HID Hi/Lo/Fogs
Interior:
All LED Interior
D1SCSS
01-25-2016 10:14 PM
mzoomora
01-03-2016 07:06 AM
