2004 Silverado Ext Cab LS w/408
30 Attachment(s)
Less than 5000 miles on new motor & Trans
New GM 6.0 block .030 over K1 forged stroker crank (408) Diamond 10.5:1 pistons Manley steel h-beam rods SLP oil pump and timing chain set ACI Racing rod and main bearings AFR 205 heads with Comp 918 springs and new valve train Morel lifters Comp 231/239 617/624 113 cam FAST LSXRT intake FAST billet fuel rails Torque Rush X-Link module 92mm GM TB 45lb injectors Walboro 400 Fuel pump and new fuel pump module ATI Super Damper ARP fasteners 1 3/4" LTs to full 3" stainless dual exhaust with 23” Magnaflow muffler Volant CAI SLP oil pump and timing chain New water pump Champion Alum radiator Derale dual electric fans New fan shroud Built 4l60e Yank 2800 converter One-piece aluminum drive shaft Eaton posi 373 gears Baer rotors New Hawk brake pads Wilwood master cyl HydraTech hydra-boost system Nitto NT420 tires (less than 2000 miles) Black Enkei M6 20” wheels Rhino liner & GM bed mat No major body damage but a few dings and needs paint Interior is in great condition New headliner Pioneer XM ready stereo w/ factory Bose amp & speakers AEM AFR & Fuel Pressure gauges Escalade dash 215,000 miles $15,000 OBO Clean title in hand Located in Escondido, CA |
Distance
It is a shame that it is so far away. I would be interested.
Where you located can I get more pics plus video won't play for any way you could share again
