2004 rcsb clone ss roller
Old Sep 16, 2013 | 11:00 PM
RoadKill03's Avatar
Default 2004 rcsb clone ss roller
I'm considering on selling my 2004 Chevy clone ss truck as a roller. Truck has 51k original miles on body. Truck is well kept and is garaged 100%. It does not have a motor or transmission. Will let it go for $15,000 FIRM! . Here is a rundown of what it has and you can't duplicate this truck for the price, not even close.
XRP black breaded 6AN transmission lines with black XRP fittings
Russle transmission cooler with XRP black breaded line and black XRP fittings
Differential narrowed 3 inches on both sides/C clip eliminators 9 inch housing ends
Moser axles
Moser girdle cover
Moser stud kit for posi main caps
Custom tubular transmission crossmember
Full spool with 4.88's
Wilwood disc brakes all around
Wilwood master cylinder
Wilwood proportioning valve
Bogart D10 bolted with bead lock on rear 15x12's and fronts 15x4
MT 29.5x13.5 rears, MT 28x4.5 front tires
Custom 4 link setup
A.R.T anti-rollbar
QA1 coilovers on rear
QA1 front Coilovers on front
Odyssey battery relocated to the back
Billet battery cut off switch
Tayler positive and negative 0 gauge wire
Driveshaft loops
Custom fuel cell
XRP Black breaded 10AN line with all XRP black fittings
XRP Black breaded 8AN return line with all black XRP fittings
Magnafuel 4303 pump with 2 filters
Magnafuel 75 micron fuel filter
Magnafuel 10 micron fuel filter
Magnafuel dual relay fuel pump wire kit
Auto meter 2 gauge piller pod
Auto meter 2 1/16 wide band gauge
Auto Meter 2 1/16 fuel pressure gauge
Auto Meter 5 inch tach with shift light
Scat racing seats driver and passenger adjustable
Custom seat brackets for proper hight
Simpson red 5 point harness with cam lock driver
Billet front coolant bypass fittings with black XRP hose and fittings
Grant steering wheel
MSD 2 step
05 electric fans
05 radiator
And much more....
Old Sep 17, 2013 | 10:34 AM
What number can i contact you to?
Old Sep 17, 2013 | 10:45 AM
tarinitup's Avatar
9 Second Truck Club
Buy it Jesse. Would look nice with turbo under the hood.
Old Sep 17, 2013 | 11:12 AM
RoadKill03's Avatar
Old Sep 17, 2013 | 12:05 PM
OUT2WIN's Avatar
Damn I would love to have this truck. What kind of deal would you make if you put a tranny and engine? (if you even care to go through the trouble) I dont care if its a stock 4l60/5.3 or 6.0 as long as it ran.
Old Sep 17, 2013 | 10:39 PM
jgb454ss's Avatar
Bump for a very nice truck..seen it in person
Old Sep 18, 2013 | 01:01 AM
walhan_qtr's Avatar
10 Second Club
very very nice... where are you located? more pics? interior??
Old Sep 18, 2013 | 07:24 AM
RoadKill03's Avatar
Located in Edinburg Tx
I'll try and get better pics. It's been raining alot and haven't been able to take pics.
Old Sep 20, 2013 | 11:31 AM
454navyss's Avatar
What transmission is it set up for? Is the wiring harness intact? Would you consider trading for a running vehicle?
Old Sep 20, 2013 | 03:00 PM
RoadKill03's Avatar
Harness has not been modified at all. I was running a 4L70 on the truck. No I'm not looking for trades.
TTT need it gone guys.
