| turbo6c3 |
Sep 27, 2015 07:39 PM |
01 c3 ecsb awd 6.0 turbo
5 Attachment(s)
Pro built 6.0 LS-1 with a 76mm turbo. 600-650 HP at 9psi of boost on pump gas. Can be turned up to over 20psi with race gas! E-boost 2 electronic boost controller lets you add boost with a touch of a button. Forged Diamond 9 to 1 pistons with Hellfire rings. Ported 317 heads. BBK TB with custom 4" cold air kit. Full ceramic coated header turbo kit, not upside down factory manifolds. AWD all the time, 20" wheels with new 295 tires. New bulletproof 4L80e 4x4 trans swap, with P.I. 3 disc lockup converter, safe to 1500HP. Rebuilt T-case safe to 1000HP. Huge intercooler, Snow water/meth injection, TurboSmart blowoff valve, EGT, A/F, posi, custom driveshafts, big brakes, edelbrock shocks, hellwig sway bars, etc. This is a very nice truck inside and out. Handles GREAT! Custom paint, leather heated seats, 200 watt rms 12" sub. under rear seat, 6 disc changer, speakers, etc. Less than 20,000 miles on rebuilt engine. 50 miles on new trans and T-case. Synthetic fluids from day one. Previous owner spent over $100k on this truck! Runs great on 92 octane at 10psi+ boost. With race gas and straight meth in snow system you could up the boost to over 20psi. Truck/Drive train was built for that. She makes amazing noises when she takes off! All 4 tires grabbing mostly, turbo spools, then the blow off vents loudly!!! Averages 10 mpg @ 9psi. Turbo kit is from Arizona Speed & Marine. The truck is now on Atlanta craigslist also, with more pictures. GMC C3 AWD TURBO LS-1 PICKUP Must sell, getting married.
