Truck disabled, need help identifying hose
#21
If hitting the bottom of the tank will make the truck start, you've got a bad fuel pump.
I'm with these guys, walbro 450 and a HotWire kit is what I'd go with. Supposed to be E85 compatible. And ditch the KB booster.
And stop buying fuel pumps on Amazon! Have you guys ever heard the term "seconds"?
You talking about a Racetronix hotwire kit? One of these? http://www.racetronix.biz/customkiti...FPWK-017WX&eq=
Where do you get seconds? I was wary of getting an OEM knockoff pump or one that was not a flexfuel pump, so I just typed in the part number and ordered it on Amazon.
I actually have an Autometer fuel pressure gauge sender on the fuel rail, but the gauge never worked right and I never put the schrader back on
#22
I will not back away from the keyboard and this man could have known for sure if the pump is bad as he sat on the side of the road waiting for the tow truck. Try using your brain and not being fool so often.
Funny thing is just two days ago I did this exact same thing on a ford. Guess what nothing came out of the valve, the relay clicked with the key. I replaced the pump and hot diggity it freaking drove away!!!!!!
#24
Hunt&Fisherator
Are you really that freaking stupid. The tiny bit of fuel that would spray out would not fill an eye dropper. If the pump wasn't working then nothing would come out because the injectors would have bled off any pressure. If After that you would need to confirm the relay and fuse are good and you have 100% made sure the fuel pump is bad. Per chance the pump was working approximately 3 drops of fuel would have sprayed out of the valve and I would have looked elsewhere. Chances are if fuel made it to the rail the pump is good and you would be looking for other issues.
"Approx 3 drops" sure it couldn't possibly be 4?
I was simply stating that the fuel pump could be moving enough fuel to get your magical 3 drops and the vehicle still not run because it is not making the required pressure... I've seen it more times than I can count. This is not just my tire shop monkey testing like you like to conduct, I was a certified Ford tech for a few years and have since moved on to greener pastures... Flow does not mean there's pressure... Period.
So before you start throwing names around. .. How bout ya do a little light reading on the subject.
#26
You're a ******* riot....
You implied you would be spewing fuel in a large quantity. I would be willing to guess that the fuel that would spray out would not half fill a pop cap. Honestly not much if any more then 3 drops from a small eye dropper.
Mossyoakglock
07-17-2015 08:30 AM
GreyChevy
07-07-2015 08:57 PM
