Truck disabled, need help identifying hose
What do you think the problem could be?
I'm also running a Kenne Bell BAP to it triggered at 4psi. When I hit the bottom of the fuel tank with a tire iron, it would fire right up. I didn't try it last night because I forgot and didn't think that was the issue with so much fuel in there.
11 Second Hall Moniter
If hitting the bottom of the tank will make the truck start, you've got a bad fuel pump.
I'm with these guys, walbro 450 and a HotWire kit is what I'd go with. Supposed to be E85 compatible. And ditch the KB booster.
And stop buying fuel pumps on Amazon! Have you guys ever heard the term "seconds"?
