Machining Wheels???
Old May 22, 2022 | 04:42 PM
Rockrz's Avatar
Default Machining Wheels???
Does anybody know where I can find a machine shop that does high quality work that has experience machining alloy wheels?
I have a pretty simple job I’m needing done by a machine shop and it needs to be done right. I have a hub I can ship to them from a truck like mine so they’ll be able to see the exact amount of material to remove...
I want to put some GM wheels (Hub Bore Size 78.1 mm) on my midsize truck (Hub Bore Size 100.3 mm) so the bore needs to be made 22.2 mm larger (both wheels have same bolt pattern, so that part is good to go).
The machining only needs to be 1/2 inch deep so this should be a simple job.
So, if anybody knows of a machine shop that has experience doing this kind of work and they are known for doing good work... please post their contact info. Thanks!
Old May 22, 2022 | 05:29 PM
arthursc2's Avatar
Any CNC machine shop in your area can do this
Old May 22, 2022 | 05:31 PM
Rockrz's Avatar
Oddly as it sounds... the few shops I've talked to in my area refuse to do this because they say altering the wheel would be a legal liability for them.... in other words, they are skeered
Old May 22, 2022 | 06:40 PM
arthursc2's Avatar
I have a shop here in Abq that will do it
LAD Engineering
(505) 508-3870
Old May 22, 2022 | 06:47 PM
Rockrz's Avatar
Cool, thanks.
I'll give them a call...
Rockrz
May 27, 2020 06:50 AM
Rockrz
Apr 5, 2020 10:56 PM
damii12
Feb 14, 2014 01:20 AM
