Consumer Reports Motor Oil comparison....
This is an interesting read....
Originally Posted by Consumer Reports Article
None of the tested oils proved better than the others in our tests. There may be small differences that our tests didn't reveal, but unless you typically drive under more severe conditions than a New York cab does, you won't go wrong if you shop strictly by price or availability. Buy the viscosity grade recommended in your owner's manual, and look for the starburst emblem. Even the expensive synthetics (typically, $3 or $4 a quart) worked no better than conventional motor oils in our taxi tests, but they're worth considering for extreme driving conditions high ambient temperatures and high engine load or very cold temperatures.
http://home.mindspring.com/~ed_white/id11.html |
Good Reading Alright. I Prefer Mobil 1 Myself. Thanx.
Well in 10 years oil has changed a lot.
:judge: |
Why would you measure the wear on camshafts and lifters? Are they known for wearing out in a GM 4.3? I'm glad they did measure the bearings. Why not the cylinders and pistons??? They get scratched up a lot more and become out of round.
Just my 2 cents.. |
