03 Silverado AC issues, PLEASE HELP
2003 Silverado, originally a 4.8 4l60, now a 408/4l80. Manual AC controls. The AC compressor clutch will not kick on until you rev the truck up. I have checked the low pressure switch and it is grounding as it should. The pressure transducer is receiving 5 volts and putting out 2 which seems to be normal. I can manually control the ac clutch with efilive and everything works as it should. The compressor is not recieving voltage until you either rev the truck up or manually tell it to kick on with efilive. Once you rev the truck up the clutch kicks on and everything is fine until you either turn the ac or the truck off. Any other ideas that may be causing the issue? This truck also has an electric fan conversion. Thanks
Not sure if its even realted but I had a dodge cummins truck that you had to rev before the compressor would kick on. After the initial rev it worked flawlessly untill you shut the truck off. That one turned out to be the clutch on the compressor being wore out.
My 2000 does wierd stuff like that. I just two foot it when im at a red light or stopped in gear. Bump it into neutral or park and the AC works fine. but not in gear at idle.
