-   TrailBlazer SS (https://www.performancetrucks.net/forums/trailblazer-ss-178/)
-   -   TBSS moddify direction? (https://www.performancetrucks.net/forums/trailblazer-ss-178/tbss-moddify-direction-525487/)
GrizzlySS Jan 10, 2014 06:07 AM
I have a 2006 TBSS as a DD that I would like to mod, although I have no idea which way to go. Currently I have PS longtubes and 3" back to a borla xr1. Would anyone have some guidance on the direction I should take keeping it a DD? I've never really messed with LS series engines. I stepped up from a 2012 Genesis Coupe. This TBSS is a whole different beast. :devil:
03sierraslt Jan 10, 2014 09:54 AM
What are your goals for it? How much power do you want? What's your budget for it?
GrizzlySS Jan 10, 2014 01:40 PM
Kept as a DD, I'd be happy with 550-600hp. Nothing too drastic. Since I really haven't messed around with LS series engines, I'm not sure how much it would take to get me to that goal.
03sierraslt Jan 10, 2014 02:02 PM
I would suggest some boost and a 4L80e conversion. Start setting aside money.
A cam and 10psi should get you to that power level, but your 70e trans will not like it.
thewrx Jan 28, 2014 11:53 AM
4l80 and stall will be first on the list, your trans will go don't let others convince you that it will hold.
Maggie's are the tried and true bolt on no other mods necessary for reliable 500whp 11 sec truck. I personally have a D1 but went through a shit ton of other changes before I got there. You will need to address oiling issues with a minum of pcm pickup tube or better yet C6 pan conversion. Once you start going turbo route there are either setups that are marginal at best like the STS or a full blown custom setup which usually runs $$$$. Also a good rear suspension setup will do wonders for ride quality and consistent launches.
Vortec350ss Jan 28, 2014 01:51 PM
At what point is oil starvation on these a real concern and warrant the oil pan mods, or pick up tube mods?
sammygroundzero Jan 28, 2014 08:49 PM
C6 pan would ne the first thing id do on a tbss oil starvation is a bog issue on tbss and bye bye engine without mods
thewrx Jan 29, 2014 08:20 AM
Seems to be all over the place. however, once i started cutting 1.7-1.8 60ft is when i could see the psi drop on my logged runs.
Vortec350ss Jan 29, 2014 09:53 AM
The different pick up tube looks like its very close to what comes in our trucks or in almost anythign with a normal pan... I wonder fi that would be a cheaper fix. Maybe overfill the engine slightly to make sure there is better coverage even when it sloshes.
Why they didnt go with a dry sump on these is beyond me... this oil pan and 4wd system is seriously engineered and I have a hard time believing the dry sump would even be more expensive... not to mention the obvious gains that can be had as well as safety.
JustAGoat Feb 13, 2014 01:23 PM
So does Grizzly have a AWD or a 2WD? A modded pan would be on the list if AWD and a c6 pan would be on the list if 2WD. For the power you want I wouldn't worry about upgrading the tranny to a 80e unless you were 2wd then I would think about it. A modded 70e will do just fine if your AWD. If you have a AWD I would highly recommend up grading the engine cross member to a LC32 Cross Member!! I have a ton more room on the back side of the Motor/Diff. Electric Fan goes with out even mentioning to get rid of the clutch fan drag. Then I would keep the motor stock and do a Maggie charger to get in your power goals...
