TB SS swap engine ?
I bought a 2007 LS2 TB SS engine & trans to transplant into my 68 Chevelle. What I need to know is what front accessory configuration these engines are considered, truck, car ? I'm planning on an ATI type Underdrive pulley and maybe an Alt. relocation and I'm not sure yet if the tall Intake is going to fit under my hood so a new water pump may be in the picture as well.
So what I need from one of you guys is what I should be looking/asking for when I start calling suppliers for parts as not to be clueless. http://i78.photobucket.com/albums/j9...e/DSCF2621.jpg Thanks, Tony |
It is a truck setup.
If your already going to run in to clearance issues with that intake might as well swap over to the car intake now because that'll require a change of acc. as well.
Yes thats what I'm tying to figure out because if the intake doesn't fit I need to change-out the water pump and if I do that I think it changes the front elevation ( fore/aft) so that would mean the Alt. & PS pump pullies would not line-up. Not sure about the A/C pulley though.
Thanks, Tony |
It is a truck set up... Best thing to do would be to call a speed shop and ask them.. Go with the fast intake!
