saab 9-7x
Looking at a 06 saab 9-7x and got some questions. The motor is a Gen 3 correct, and what Trans 4l60e?
LS2 is a Gen 4. they are known to have oil pan problems. (sucking dry)
trans is a 4l70e. |
Originally Posted by Chevy_King1500
(Post 5273187)
trans is a 4l70e. |
the 5.3 is also a gen 4, and the trand is a 4L60e with the 5.3.
This is not an aero. Its the same car I dd, but I did a 6.0 swap in mine. |
4L70E are known for transmission problems, run a good trans cooler and hope for the best, any extra power is gonna hurt the life of the trans, just a matter of time before they go. As for the oiling issue im not sure if its in the 5.3's or not but the oil tube on the TBSS I know is located at the front of the pan and on hard launches it sloshes to the back and starves the pickup tube of oil.
I actually just bought an 2005 97-x with a rod knock and I agree with all her info here. I know there is a baffle that someone makes that helps with the sloshing. Also they are correct that it's a gen 4 but your 06 is a 24x crank so keep that in mind. I'm in the process of swapping a gen 3 5.3 into mine at the moment. |
Originally Posted by 2004silvy
(Post 5443143)
I had a 9-7x Aero for a short time. It was a great vehicle but only averaged about 14mpg with mixed driving.
The oil starvation issues generally stem from HARD acceleration from loading up the trans with the brake to 2-3k and then matting it (because racecar). Not launching it will help the trans live a normal life. The LS engines also have a tendency to consume some oil. Keeping an eye on the oil level and either topping it off or adjusting your oil change intervals are important. I would also advise to use 7 quarts when refilling. |
Put about 3k mi. On the Saab since the motor swap. Installed baffle and use 7qts of oil. Oil still full and oil pressure does not budge under any sort of driving. 50 psi all the time.
