TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Boost Options
Old 08-22-2013, 01:43 AM
Registered User
Alex^Heilbronner's Avatar
Default Boost Options
Does anyone have any suggestions on boost options for my TBSS? I was thinking about a STS rear mounted turbo system.
Old 09-06-2013, 12:44 PM
JustAGoat's Avatar
Are you AWD? What Trans do you have? Daily driver? Why do you want to go so fast?(roll racing, quarter mile, autocross)
Old 09-08-2013, 06:27 AM
Registered User
Yes it's a daily driver. Its a RWD with the 4L65E. I have long tube headers (no cats) with a True Dual Borla (XR-1 mufflers). Lv4 trans rebuild kit w/ 3000 stall. Cold Air intake, ECU reflash, PRC ported heads, comp cams (not sure on specs) valves, springs, and retainers. I like to go to the track when I get the opportunity.
Old 09-17-2013, 12:40 PM
obsssd72's Avatar
I loved my STS Turbo kit worked great on my LS1 Firehawk
Old 09-20-2013, 09:06 PM
LS1TRUCKGUY's Avatar
you already have the exhaust, i would put a TVS2300 on it.
Old 09-21-2013, 03:55 AM
Registered User
Are there any other internal modifications that I would need in order for this to work, or are the stock internals I have remaining suffice? I don't even know much about the reliability of LS2s in modified applications.
Old 09-23-2013, 02:50 PM
Randy92Z's Avatar
Another +1 for a TVS, instant boost off idle makes a fun daily driver! The LS2 will take the power no problem, it's your tranny you have to worry about.
Old 09-23-2013, 03:15 PM
Registered User
What's wrong with the transmission? Will a the build kit not work for it?
Old 09-23-2013, 08:29 PM
Randy92Z's Avatar
Sorry, I just saw that you have a lv4 trans. You should be ok with that.
Old 09-24-2013, 05:24 AM
Registered User
Any other suggestions? What should I do first or is the ls2 pretty well off already.
Quick Reply: Boost Options
