Lets talk abut Efan
Hey guys im looking to see what sthe best E fan for the our trucks. I was looking at the ADM kits. I believe they sell the two fans and the wireing really kit. Any inpute will b thanked..
OEM 34" radiator, OEM fan assembly, Nelson harness.
Originally Posted by Beau@SDPC
(Post 4782634)
That too, :). Forgot that part, haha, thanks!
Sorry guys but im kina lost. Can you guys explain a bit more??
I had the c6 fan setup on my old tbss and had a few problems but it worked pretty good..
If i had to do over i would do te ls1 dual fan setup OR a Spal fan kit from Pcmforless with there harness.. ADM makes some damn good stuff but i dont know what there offering since they dont post much on the tbss stuff..
(Post 4782634)
Originally Posted by Slammed96
(Post 4782794)
Dont forget the Nelson tune to run the fans off of the ECM :nod:
(Post 4782810)
Originally Posted by Don Cheto
(Post 4783121)
If you use an OEM fan assembly, Nelson Performance makes a harness that ties them into the factory harness, and once the computer is tuned to accept them, they work like factory installed fans.
Originally Posted by andrew383
(Post 4783196)
You guys have a kit to put a 34" radiator in a tbss????
(Post 4783463)
Most folks are taking radiator and/or fans from 05+ Trucks. Trucks came with either 28" or 34" radiators, 28" was usually fan clutch, 34" usually e-fans. If you do not have a 34" radiator, OEM 05+ E-Fans will not fit. You must have the 34" radiator for the OEM fan shroud to fit. If you have the smaller 28", you can use LS1 fans, or they are quite a few companies making aluminum shrouds w/ aftermarket fans.
If you use an OEM fan assembly, Nelson Performance makes a harness that ties them into the factory harness, and once the computer is tuned to accept them, they work like factory installed fans. Good question. Not sure if you can even fit a 34" in them ???? I'll look into and see what I can find. |
Woops! My mistake. Did not even realize what section this was in. I read "our trucks" and rolled with it. That's what I get for using the "New Posts" feature.
I apologize! |
Call allen or erica at nelson performance he makes killer harnesses!
My pcmforless harness on my aero burnt up http://i194.photobucket.com/albums/z...-30-20_713.jpg Allen is making me a new harness... |
