TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
02 Envoy rear differential help please
Old Nov 20, 2013 | 06:44 AM
Phil Hicks's Avatar
Registered User
Default 02 Envoy rear differential help please
I recently had the rear differential replaced in my 02 Envoy and I believe they installed a differential with the wrong gear set. My envoy came with the tow package and 4:10 gears. When I test drove the Envoy I noticed that my speedometer was 10 MPH off. My GPS said I was going 70 and the speedo indicated 60. This is a 4 wheel drive unit and when I put it in 4 whd (in snow) it pulled hard to the right almost into a ditch. What I am asking is, are there marking on the rear housing to indicate what gear set is inside? I need evidence to take this back to the repair shop.
Old Nov 20, 2013 | 08:50 AM
JurgenS's Avatar
When you jack up the wheels, you can count it. Rotate your wheels one full turn and your driveshaft will make 4.1 turns assuming you have 4.1 gears.
You could also remove the the differential cover...
Corvette454l88
Sep 1, 2016 01:24 AM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
