yet another gear question
i have bone stock 2013 4.3L v6 4 speed auto rcsb with 275/55/20 which is right at at 32" tire with 20x9 wheels that id say were medium heavy. i definitely felt a weight increase after changing from stock 17s. tow light loads pretty often. 70% city driving, 30% hwy driving. stock gears are 3.23.
question: 3.73 or 3.90 or 4.10.
ive honestly been leaning toward 4.10 but dont want screaming highway rpms and even worse gas mileage than im already getting.
Also im thinking that the 3.73 would probably put me back at stock power with the 32's but i am wanting slightly better acceleration than when I had the stock 17's but IDK ??????????????
ALL opinions welcome please!!!
Don't fear gear.
I'd look at 4.10's as the starting point, and consider going deeper. Your truck is working hard to move the weight + the wheels, having more gear and slightly higher RPM won't be nearly the trade-off you're thinking it might be.
. that would have probably solved all problems in itself.
also i know i can get oem 3.73s but do they make oem 4.10s? and ive read somewhere that the lowest gear i can swtich to is 3.73 with my stock rear end carrier? is this correct?
Last edited by jbryant777; Nov 21, 2014 at 10:11 AM. Reason: added another question regarding topic
around 1800rpm at 70mph. with a v6, you need all the gear you can get. its all about mechanical advantage. yes you will be turning a few more rpm, but the engine is not working as hard. you fuel mileage will increase.
