TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
track tires.
Old Jan 30, 2013 | 08:35 AM
trevorh1's Avatar
Default track tires.
hey everyone just a simple question. i know most everyone from what ive read anyways runs 28" tires at the drag strip. im considering trying the hoosier QT dot 26/9.5/16 thinking of the shorter one becuase i have the stock 3.42 and should help 60' and i only run 1/8mi any input appreciated. thanks trevor
Old Jan 30, 2013 | 09:22 AM
outlawz2004's Avatar
When I had 3.42s I ran 26" tires at the track and they worked out great.
Old Jan 30, 2013 | 10:02 AM
trevorh1's Avatar
thanks for the reply outlaw. thats what im thinking ill run till i get the 3.73 or the 4.10 in it. i see in sig it says you have a dual tune? sounds like what i was wanting kind of. can you elaborate on that a little but please? thanks.
Old Jan 30, 2013 | 10:45 AM
I believe its just the low and high tables tuned, when you run the higher octane it will run a little better. I run 89 octane most of the time, and when I plan on going to the track I run the better stuff. I do get better fuel mileage running the higher octane though.
Old Jan 30, 2013 | 11:37 AM
custm2500's Avatar
Ph.D. in HUBRIS
The 26" tire will work fine. A good deal of people run the shorter tire for plenty of reasons.
It will help your gearing like you said. I beleive the biggest reason most guys don't run the 26" tire is because it looks goofy. I borrowed a set once. The worked well but they did look goofy!
Old Jan 30, 2013 | 11:48 AM
trevorh1's Avatar
ok that sounds like what i need im still running stock tune with my trick flow cam. im gonna wait till i put the stall in it to get it tuned.
Old Jan 30, 2013 | 11:49 AM
trevorh1's Avatar
heck i dont care if it looks goofy or not as long as they work. i just wont have them wheels that stick out of the wheel wells like 3 inches. thats goofy looking.
Old Jan 30, 2013 | 12:19 PM
Ran mine on a set of 2000 silverado stock aluminum 16s. Fairly light wheel and tire combo.
Old Jan 30, 2013 | 12:28 PM
trevorh1's Avatar
thats what ill run them on i have a stock set of 03 16s ill use.
Old Jan 30, 2013 | 01:00 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
What's the cut off with gearing before you have to switch to a 28" tire?
