TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
towing with yank 3k stall
Old Sep 6, 2013 | 02:49 PM
Z71crawford's Avatar
Default towing with yank 3k stall
Who here tows with their stall? ive used the search button and not much comes up. My setup is 5.3 silvy, 4l60, full bolt ons, yank 3k stall, and 4.56 gears. Ill be towing my dads 32 ft scarab offshore boat every once in a while. Is this to much for a 3k single disc stall? Oh boat weights 7500-8k loaded
Old Sep 6, 2013 | 03:38 PM
black00chev's Avatar
Slowest turbo build ever!
I think most people on here are going to tell you that, that is probably a little too much weight for a single disc converter with that stall. Maybe ok if the stall was a few hundred RPMs lower.
Old Sep 6, 2013 | 09:35 PM
I'm curious to see how it'll do I'll just take it easy and see how it does
Old Sep 6, 2013 | 10:39 PM
as long as wherever youre going is relatively flat then you should be fine.
Old Sep 7, 2013 | 05:47 PM
foxnutz's Avatar
Heat will be a problem. Dont let it get out of control. I have a hard enough time keeping mine cool in stop and driving that I haven't dared hook up a trailer since the converter went in.
Also the extra weight will make the converter stall higher. Be ready for it when getting rolling from a dead stop.
Old Sep 7, 2013 | 11:06 PM
custm2500's Avatar
Ph.D. in HUBRIS
Are you sure the boat is that heavy?
I have a 3200 FTI stall and have pulled a 4000-5000 lb car hauler with a probe on it from DC to NW ohio through the big hills and didn't have a problem. I have also pulled a 6000-8000 lb skid loader but that was for only about 15 miles each way. A light weight camper (4000 lb I guess) for about 25 miles. Also a 28ft boat on a two axle trailer a few times each trip atleast 20 miles.
All of that and more with a D-maxx cooler and never had an issue. I think you are pushing it if the boat is that heavy and or have many hills. If you are on flat land or slightly heavy on your weight guess you should be alright. Just gotta make sure you have a big enough cooler!
Old Sep 8, 2013 | 12:06 AM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
Going into lockup with a 10" clutch with that much weight sounds a little scary.
Old Sep 8, 2013 | 08:10 AM
swift700's Avatar
I accelerate fairly hard and let off the gas a bit for shifts. I tune my lockup out in tow haul and when I want lockup I let off the gas and switch to normal for a gentle lockup.
Old Sep 8, 2013 | 01:35 PM
Whitecrewcab's Avatar
I haven't pulled anything quite that heavy, but I've had probably 6000lbs behind my 9.5" Vigilante that stalls about 3000 in my truck. I have made probably 10 trips completely back and forth across Texas from the flats of east Texas to the mountains of El Paso. So far, so good and mine locks up just fine. It will drop out of overdrive and start staying in drive once I start climbing the hills, but it never slips.
Old Sep 8, 2013 | 08:31 PM
andrew383's Avatar
traveling mod
How tight is the converter? I run a circle-d 278mm that will flash to 3100rpm with my camper on the back (7klb's roughly). Ive pulled from indiana to texas and back mid summer with out the tranny going above 180* in stop n go.
Id say do a trial run and see how it does.. While pulling up the boat ramp tho id prolly use some gear reduction (4lo)
