TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Does my truck have a torsion lift
Old Jan 9, 2008 | 09:13 AM
Default Does my truck have a torsion lift
I sold the lightning and picked up an 04 z71. I was reading about torsion lifts on these trucks and I hear that to fit 285-75-16's I need to crank the torsions. Well got some yokohoma grabber 285-75-16's on it with no rubbing so far (came that way). It doesn't look level though. Sorry don't know much about these trucks yet.
Old Jan 9, 2008 | 07:33 PM
formerly 20032wdsilverado (8/29/2011)
If you go under your truck and look at where the long bar that comes off your lower control arms meet just under the cab, and there should be 2 bolts that go up into that cross member, if they are all the way in, then they're cranked, if not then you could crank them to level the truck but be sure to measure the fender height before and after and adjust them accordingly.
Old Jan 11, 2008 | 05:16 PM
hard2kill's Avatar
on stock wheels your yokos should clear without cranking as long as theres no sag in the stock bars so it is possible that it is not caranked but as stated above take look for yourself
Old Jan 11, 2008 | 05:33 PM
xsports33's Avatar
before you start cranking the bolt make sure you jack up the front of the truck. Don't crank the bolt when it's under load. Sure it'll work the first few times, but you'll grind down the bolt and sooner than later it won't sit correctly in the torsion key and it WILL slide out. I've seen it happen more often than i'd like.
5.3Okasai
Mar 9, 2022 01:07 PM
wrb002
Aug 31, 2015 12:00 PM
bgray
Jul 23, 2015 10:56 AM
black6spdz
Jul 16, 2015 01:32 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
