TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
3" spindle lift with 35's???
Old 08-12-2018, 11:33 PM
Registered User
robert_hall's Avatar
Default 3" spindle lift with 35's???
new here but i was just having some rubbing issues. i have a 03 chevy silverado 1500 2wd. 17x8.5 wheels with 35x12.5 tires on a 3inch spindle lift everything else is stock and i rub a bit! any suggestions? id like to keep these tires too without down sizing
Old 08-13-2018, 06:39 PM
Mconcha's Avatar
Find a bfh and swing away. But seriously to fit 35’s on a nbs w/ only a spindle lift takes some cutting, usually the front bumper valance minimum. Then pop off the inner fender liners and find the areas that rub and hit or cut those down, and reinstall the liner in the factory points if possible or with zip ties discretely.
robert_hall (08-13-2018)
Old 08-13-2018, 07:02 PM
Registered User
what do i do with the e brake cable
Old 08-13-2018, 07:43 PM
Mconcha's Avatar
the E brake cable mount or the whole thing? How bad and where is it rubbing?
Old 08-27-2018, 06:45 AM
RySmDPT14's Avatar
On my 04 I rubbed with 35’s on 6” lift. trim front valance and take mud flap off the front, if that’s not enough either do a small body lift, roll the front fender (cal fender mod) or smaller tire. The e brake cable I was able to unhook it from the frame bracket for clearance.
5speedsilverado
01-03-2017 07:18 PM
kaze_v8
01-03-2017 02:01 PM
Vexracing
12-01-2016 09:19 PM
yellow2000S/R
10-30-2016 01:19 PM
Nine Ball
36
12-14-2002 04:55 PM
Quick Reply: 3" spindle lift with 35's???
