TOOLS & FABRICATION Hand | Power | Hydraulic | Pneumatic | Welding
torque wrench suggestions
Old May 4, 2021 | 11:16 PM
TXsilverado's Avatar
Pay 1 once, Cry once and take care of your investment.
Never use it to break bolts loose. Always wind it down as far as it will go to relax the spring. Even the lowest torque setting can cause the spring to loose its tensioning properties over time and throw off the accuracy.
pay once cry once is how I'm looking at it. I always relaxed the spring and kept the tool in the box when not in use.
Old May 4, 2021 | 11:25 PM
adriver's Avatar
CDI is a good torque wrench as Jake mentioned. They are owned by the Snap on corporation.
Personally I own several Snap on Torque wrenches in various torque ranges. I never had a great feeling with the Electronic type torque wrenches until Snap On's newest version. I didn't purchase them all new either, some were second hand purchases but in like new condition. If I had not purchased those at various times I would definitely get the CDI to save the money. The only difference with the CDI version is the ratchet head.
I do not recommend any of the hardware/ tool store brands.
I bought the Craftsman torque wrenches because they were on sale from $80 to $40, have reversible head for left hand threads, and liked the warranty policy. Is the problem with em just going out of spec eventually? Would a better brand some how hold in spec for longer?
Old May 4, 2021 | 11:27 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I have had this argument with several people. Even a "friend" of mine didn't want to pay and was using a Harbor freight until he had an issue...
He kept looking at alot of use torque wrenches. I explained to him that alot of the older "quality" torque wrenches are no longer rebuildable so buy a quality one. I kept sending him links to good ones.
Against my advice he bought a little one for transmission stuff because it was cheap.... when he showed me I informed it was no longer rebuildable. At the time it was calibrated less than a year ago and was supposed to be some surplus deal that was being sold off. I told him it was more likely not able to be calibrated any more and they were forced to get rid of it for liability. Would I trust it, No.
Old May 4, 2021 | 11:44 PM
1FastBrick's Avatar
Did you ask were you can get it calibrated??? There are people that will test them for a nominal fee. There might not be parts available for it if it needs a rebuild after that.
I watched some one drop one of my torque wrenches. Fearing it might be out of spec when I need it, I wanted to have it tested. It was like $45 to have it tested and then if it needed a rebuild that would be extra. Or for $60 they just replace the parts and recalibrate as part of the rebuild process. I just had them all rebuilt and certified after that.
I recently bought a Cobalt Inch Lbs torque wrench. Seemed decent until I tried to put the stupid block off plate on the oil pan. After I ripped the threads out, I put in heli coil's. After I ripped those out, I had to use a Keen cert.
While it torques some things properly, that particular value is not accurate. The cost of both types of repair kits and specific drill bit's is about what I paid for that pile junk form Home Cheapo...
Old May 5, 2021 | 07:57 PM
adriver's Avatar
No, I was curious what the difference is between a cheap torque wrench and a high quality one.
Old May 5, 2021 | 09:18 PM
1FastBrick's Avatar
The quality of the parts inside like the break away mechanism.
Old May 9, 2021 | 02:54 PM
smokeshow's Avatar
Mod with training wheels
This is the guy I use when I care about the torque value that my bolts receive. Otherwise, it's a toss-up between the craftsman and gutenteit.
Old May 11, 2021 | 10:57 AM
chevymec's Avatar
I have Snap-On, Mac, Cornwell, and some cheap ones. I have never had a problem. I looked up the CDI as mentioned. The prices look real good. I have been looking a click style 3/8 Ft/Lb flex head torque wrench and looked at the Gear Wrench brand. Haven't pulled the trigger yet. My only 3/8's is a digital Cornwell flex head and I wanted a non digital.
mcfarlnd
Aug 10, 2008 01:25 PM
white1
Aug 17, 2007 02:11 PM
white1
Aug 16, 2007 03:46 PM
CHEVY6000VHO
14
Dec 26, 2006 09:59 PM
