-   TOOLS & FABRICATION (https://www.performancetrucks.net/forums/tools-fabrication-174/)
-   -   Craftsman variable speed bench grinder won't adjust speed (https://www.performancetrucks.net/forums/tools-fabrication-174/craftsman-variable-speed-bench-grinder-wont-adjust-speed-525261/)
Atomic Jan 3, 2014 09:23 AM
I was given this grinder a couple christmases ago, havent really ever used it until recently. Craftsman Variable Speed 8 Bench Grinder: Power Up With DealsSears
The variable speed knob doesnt do anything, the the unit appears to run at full speed all the time. It worked the first couple of times I used the unit but hasnt since. Thing maybe has 20 minutes of run time on it.
I took the knob off the shaft and turned the shaft by hand to make sure the knob wasnt just slipping on the shaft and it still feels normal so I am out of ideas short of taking it apart and tinkering with it.
skeet Jan 3, 2014 09:47 AM
VFD is probably bad or the controller in the motor
silver-mod-o Jan 5, 2014 01:10 PM
I'm sure it's just a potentiometer that controls the speed... Pick one up from radio shack and wire it in and see!!!
Atomic Jan 6, 2014 08:38 AM
I pulled it apart and tested the resistance of the leads of the knob, 10.2kohms at low and 9.8 at high....that doesnt seem quite right.
silver-mod-o Jan 7, 2014 06:28 PM
No it doesn't, seems like there should be more of a range than that.
TIM Z Jan 7, 2014 07:16 PM
Your thread title= oxymoron.
Similar story , I got a nice ( I thought) craftsman timing light for Christmas 3 years ago , needed it this past summer , it didn't work , tried it on another vehicle , no dice . Wayyy too late to take it back . FML :(
TXsilverado Jan 7, 2014 07:17 PM
it's a craftman. take it to sears and get a new one.
AJII Jan 7, 2014 09:46 PM
thats only for handtools. most power tools have a 1 year warranty and you need a receipt.
TXsilverado Jan 7, 2014 10:16 PM
throw a mini shit fit and sears will cave every time.
Rudy91040 Jan 11, 2014 09:08 PM
Buy new one, take old one back and say it doesn't work. You get a new one and no problems.
