02 Silverado to 03-06 Center console
Did know what thread to post this under so I did fab I am wondering what is all needed for a 02 Silverado to get a 03-06 center console and would the cig port work? Just testing the water on this one
If you take out your jumper seat or your non fold down seat and install a center console. it should bolt right up I have a 03 that was the work truck version amd installed a set of 02 power seats in It no pr6.
100% Redneck
The wiring for the acc ports plugs right in after you feed the wires up to the console. You will need three other pieces plus the console, the knee bolster under the steering column, the glove box surround that goes around the glove box door and the plastic adapter hidden between the upper part of the console and the dash. The latter piece allows you to fasten (bolt) the console to the dash.
Tip: the glove box surround has one pop rivet holding it to the glove box door. If you don't want to pay for the glove box door at the salvage yard... bring a drill and small bit to drill the rivet out.
Tip 2: If you're removing console from a salvage vehicle... the seats have to be unbolted to remove console. Most all console trucks have power seats that need power to move to be able to get unbolted... a jump box is a life saver to move the seats. I had to disassemble upholstery seat cushions to get to the seat bolts.
You can easily see the difference in the drivers knee bolster.
BTW: I paid $30 for my console at my local LKQ pick-a-part.
RedXray (09-27-2019)
