Remote oil pressure sensor 2010 5.3l
https://cimg9.ibsrv.net/gimg/www.per...f942d23669.jpg
Disconnect plug from oil pressure sensor, remove tape from wire harness and separate the oil pressure sensor plug wiring. https://cimg8.ibsrv.net/gimg/www.per...635b00e1fd.jpg After separating the oil pressure sensor wires rewrap both sets of wires with electric tape. https://cimg2.ibsrv.net/gimg/www.per...9483d64d1d.jpg Remove oil pressure sensor using the recommended oil sensor socket and install adapter. I used (RUS-670530) Metric adapter -6AN male x 16mm male. Purchased through Summit Racing. <br/><br/>Note: The fitting going into the oil sensor port is wrapped in pipe thread tape https://cimg1.ibsrv.net/gimg/www.per...250021c36d.jpg I got 2 ft of rubber hose from O'Reilly. Using a -6AN x -6 straight end hose fitting (RUS-610025) and a -6AN x -6 swivel 90 hose fitting (RUS-610165). Fittings purchased from Summit Racing https://cimg0.ibsrv.net/gimg/www.per...39b8e31b5c.jpg I fabricated a bracket using 6061 aluminum flat bar that I purchased from Metalsdepot.com Also pictured is<br/>-Equus mechanical oil pressure gauge (EQU-6234) Summit Racing <br/>-Oil pressure sensor (purchased on Ebay)<br/>-Metric adapter -6AN male x 16mm female (RUS-640830) Summit Racing <br/>-Tee adapter -6AN male x -6AN female x 1/8 npt female (RUS-670343) Summit Racing <br/>-Stainless steel bolts, nuts, washer, lock washer and stainless steel hose clamp. Purchased at Lowe's home improvement. |
Continued
https://cimg1.ibsrv.net/gimg/www.per...7b6ec452e4.jpg
Using the supplied nylon tubing kit that comes with the gauge connect the sensor to the 1/8" npt port on the adapter tee. Note: I wrapped the 1/8" npt fitting and oil pressure sensor with pipe thread tape, sometime in the future I will replace with copper gauge tubing. https://cimg2.ibsrv.net/gimg/www.per...8c43d35691.jpg Mount bracket, then connect the oil pressure sensor plug and the hose. Start it up and check for leaks. Note: Be careful not to over tighten the AN fittings, you can always tighten more if they are leaking. If you over tighten them they will always leak and need replaced. |
Continued
https://cimg2.ibsrv.net/gimg/www.per...704595731a.jpg
Filter screen that is located underneath of the factory oil pressure sensor. I choose to remove and throw away. |
Good job man! Nice write up!
Credit goes to the guy who gave me the idea, least I could do was pay it forward with a write up.
Would it save space to do a 90 out of the block to the right and a 90 out of the back of the sensor?
