TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
MikeGyver-ed Cable Luber
Old 09-19-2014, 04:29 PM
MikeGyver's Avatar
Default MikeGyver-ed Cable Luber
My Acura shifter cable is bad and the cheapest I could find new is $65+shipping. So I thought lubing it was worth a try since i have a motorcycle cable luber. Well, the shift cable is like 4 times bigger than what will fit in the tool, so I came up with this:
Here is the cable disconnected from the trans
Old 09-19-2014, 04:32 PM
MikeGyver's Avatar
Here, I inserted the spray tube nozzle from a thick, greasy, spray lube.
Old 09-19-2014, 04:34 PM
MikeGyver's Avatar
Here, I wrapped the cable and nozzle the best I could with self-fusing silicone tape.
Old 09-19-2014, 04:41 PM
MikeGyver's Avatar
That was the last pic I could take, because when I sprayed the lube, it did leak around the seal. There was lube everywhere, down my arm even. But I would not have posted pics if it did not work. When I looked at the shift lever end of the cable, some lube made it through. Success! Not only was my idea successful, but so was the lube job. It shifts like butter again, for now anyway.
Old 10-11-2017, 09:21 AM
Aim
Aim's Avatar
This can be useful in my Freightliner, thank you.
Old 10-11-2017, 11:15 AM
03sierraslt's Avatar
Do you still have the Doily??
Idryfly5
09-02-2022 08:55 PM
chvy=power
10-20-2015 09:08 AM
GM1697
09-22-2015 09:54 PM
bisqikss
09-08-2015 03:35 AM
Quick Reply: MikeGyver-ed Cable Luber
