-   TECHNICAL WRITE-UPS (https://www.performancetrucks.net/forums/technical-write-ups-201/)
-   -   Ls7 Throttle Body (https://www.performancetrucks.net/forums/technical-write-ups-201/ls7-throttle-body-527769/)
a.vinson Mar 23, 2014 03:52 PM
Ls7 Throttle Body
Anyone with 04 Silverado with the 102 fast intake ever use Ls7 Throttle body?
Figured it would match right up with a 8 pin to 6 pin adapter. HELP ME OUT.
oakley6575 Mar 23, 2014 03:59 PM
I'm running an ls7 tb on my 03. I used a torque rush adapter and it has worked great.
a.vinson Mar 23, 2014 04:10 PM
Awesome good to here. Thanks, wanted to go with the 102 throttle body, but im not forking $700 for
oakley6575 Mar 23, 2014 04:14 PM
Just to clarify, I have the silver blade 90mm tb. I believe it came on the early ls7's and Ls2's. I bought it on eBay for $250 I think.
a.vinson Mar 23, 2014 04:18 PM
O, the one i bought has the gold blade got it on ebay for one $150. Is there much of a difference?
03sierraslt Mar 23, 2014 04:28 PM
Silver is LS2
Gold is LS3
If you are NA then either will be fine, the blade opens opposite direction on the LS2 which is irrelevant for the most part. The LS2 has a stronger servo motor which is why it is the preferred one when you are FI.
oakley6575 Mar 23, 2014 04:40 PM
Originally Posted by 03sierraslt (Post 5203524)
Silver is LS2 Gold is LS3 If you are NA then either will be fine, the blade opens opposite direction on the LS2 which is irrelevant for the most part. The LS2 has a stronger servo motor which is why it is the preferred one when you are FI.
:cheers:
a.vinson Mar 23, 2014 05:23 PM
Thanks guys. Oakley I've been looking at those torque thrust adapters how much wiring is involved if any?
03sierraslt Mar 23, 2014 05:26 PM
Just plug it in, I have one also.
oakley6575 Mar 23, 2014 05:26 PM
None. It is plug and play. You have to cut one wire in the torque thrust loom depending in what model throttle body you have.
