Get Rid of That Annoying Door Chime
3 Attachment(s)
Hey guys I was just tinkering around with my truck today and got rid of the factory door chime in the cleanest possible way (no wire cutting or fuse pulling)
If you take a peek under your dash above your gas pedal on any 1999-2003 Gm, you'll notice an interior control box, like so: Attachment 62372 Just push the clips to the side to get the box down, and unplug the wires, the box is held together at the four corners by some all-to-easy to remove prongs: Attachment 62373 Just take your soldering gun out and remove the solder from the two prongs under the round speaker, and pull the little guy off: Attachment 62374 Put it all back together and there you have it! no more door chime so you can listen to music with the doors open or work on your truck without a headache from the noise! |
Thank you.
will configure mine immediately |
i wonder if it would be the same on my 2005
