TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
Efan harness 101
Old Apr 20, 2012 | 10:32 AM
nonnieselman's Avatar
Hope it makes it more simple for you.. if you have any questions PM me..
All those astricks are from me typing that out in my notes on my iphone and when i copied/pasted it, they showed up.
Old Apr 24, 2012 | 10:34 PM
SnakeOiler's Avatar
Here are two schematics that I created: 2-relay and 3-relay.
Old Apr 24, 2012 | 11:24 PM
12sec.5.3's Avatar
If pin 42 is for temps, wt is pin 33 for?
Old Apr 25, 2012 | 07:58 AM
Thanks SO!!
Both pins can be used for Temps.
Old Apr 25, 2012 | 07:59 AM
Pin 42 is for Low speed
pin 33 is for high speed
Old Apr 26, 2012 | 09:38 PM
12sec.5.3's Avatar
I just finished wiring up my f-body efans using the 3-relay drawing from Snakeoiler. Works great, I'm glad to have that back up and running. Only thing different, I used 14awg wire for everything including motor leads but I think it'll be fine. Thanks guys!
Old Apr 26, 2012 | 09:41 PM
12sec.5.3's Avatar
Also, instead of connecting to the A/C circuit, I just have that ran to a toggle switch for now. I'll get to that a little later, I have to start gathering parts for my 80 swap...
Old Apr 27, 2012 | 02:40 PM
you can connect it to your PCM and it will work with the AC if your tune is setup right.
Old Apr 27, 2012 | 06:01 PM
12sec.5.3's Avatar
Which pin would it connect to?
Old Jul 12, 2012 | 01:10 PM
33 for AC control
