TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
Diy oil cap breather
Old 05-14-2011, 08:33 PM
beingblueeyes's Avatar
Default Diy oil cap breather
This is a basic how-to on making a oil cap breather, so before I begin just a word of warning
*I am not responsible for anything thing that happens to your motor as a result of building this or any injury’s acquired when building this
Now that that’s out of the way let’s begin. There are company’s out there that make a oil cap breather for lsx engines but charge $40+ for them. You yes YOU can built one for sub 15$ if you have some tools at your disposal and about 15 min of your time
Parts needed:
all parts from Summit racing
MRG-6375 VC BREATHER GROMMET CLOSED $2.25
SUM-G3417 BREATHER PUSHIN COTTON/GAUZE $10.95
Tools needed:
Drill press or drill
1” wood hole bit
Something to enlarge a plastic hole (1 ¼ drill bit would speed up making this by 10 min)
Tools is used:
1: take the oil cap you want to make a breather out of and using the 1 inch wood hole bit drill throw the oil cap using the inside to center the bit
2: from the top side of the oil cap start to enlarging the hole for the grommet until it is 1 1/4 inches across (this doesn’t need to be exact but the closer the better, take your time doing this and test fit the grommet and breather periodically
3: after you enlarge the hole in the top of the oil fill cap so you can insert the grommet and then the breather cut a hole in the bottom of the grommet.
4: clean the oil cap and make sure you have all the plastic shavings out of it
5: assemble and enjoy the money you just saved by putting it in your “next upgrade” fund
here it is installed on the truck
[IMG][/IMG]
any questions please ask
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 05-14-2011, 08:59 PM
makes children cry
_zebra's Avatar
nice, but the $40 ones have a one-way valve to keep oil from accidentally coming back up. any ideas for incorporating this? and also, do they carry smaller filters that would fit? i've got limited space under the hood of my vette - the one that's gonna need this soon with the Maggie on the way
Old 05-14-2011, 09:33 PM
im sure you could fit a smaller filter using the same principles as this with a different sized bushing and filter, most off the "push in" style breathers i have seen are not just hallow metal nipples the have a peace of metal on the inside floor of the filter that's angled to help prevent oil splash up into the filter
Old 07-15-2011, 08:32 AM
arnezg's Avatar
I'm a little wet behing the ears when it comes to this stuffy so excuse my ignorance for asking what the benefits of the breather are?
Old 07-15-2011, 09:15 AM
swift700's Avatar
A breather like this relieves crankcase pressure caused by piston ring blowby. It can help keep the seals from blowing out on your engine or just keep them from leaking. The crankcase breather hose and PCV also help with this problem but on a performance engine you might need more than what the stock breathers offer. A catchcan is another option.
Old 07-15-2011, 09:54 AM
TXsilverado's Avatar
breather pulls in air, pcv relievs pressure. passenger side valve cover pulls in fresh air. i dont really see a problem with getting the air from the throttle body unless you are puking oil into it.
Old 10-14-2011, 07:41 AM
Registered User
herrys's Avatar
I have used vent breathers on my past and present vehicles with no problems. Even my grocery getters. The intake and combustion chambers will stay clean for far longer than without the breathers.
Old 01-10-2012, 12:15 PM
MHSLOT12's Avatar
the cap will fit right on the valve cover with out the extenion tube !! if not enough room is a problem
Old 02-04-2012, 01:23 PM
RST302's Avatar
Has anyone else noticed the check engine light come on after doing to install, besides me.
Old 02-06-2012, 02:50 PM
262_NBS's Avatar
Probably due to the vacuum leak caused by opening up a closed pcv system?
Quick Reply: Diy oil cap breather
