-   TECHNICAL WRITE-UPS (https://www.performancetrucks.net/forums/technical-write-ups-201/)
-   -   DIY: 2" Drop Shackles on NNBS GMT900 (https://www.performancetrucks.net/forums/technical-write-ups-201/diy-2-drop-shackles-nnbs-gmt900-483264/)
gnasty1521 May 29, 2011 12:29 PM
By myself job took 3 hrs. No air tools, which would've helped a great deal.
2" inch lowering shackles for the rear of NNBS Trucks. Other brand trucks have to be similar, but this one showcases NNBS Chevrolet 07-11 Silverados, and GMC 07-11 Sierras.
BellTech P/N: 6400 $55 or so
AutoZone KnockOff (Works Perfect / Made Well / 1/2 price) P/N: 13-4100 $35 at AutoZone
**Note** Torque Values aren't given. Also tighten shackles in the air because this is when you loosened them. I tightened the Shackle bolts to 70 ft lbs and it seems to have worked out great. Hitch and everything else just tight.
Here is the link I used when doing this. Complete with step-by-step instructions and HQ pictures.
http://www.gm-trucks.com/forums/inde...owtopic=118247
This job is not major surgery, and I even used the Jack that came with the truck. I did have some jack stands for safety. But if you use a floor jack make sure it gets some good height because there is a step that involves having to get the shackle higher than the frame to get a bolt out.
Link to more talk and before and after photos.
https://www.performancetrucks.net/fo...d.php?t=482685
Hope this helps some people. I think taking the raked look out streamlines the truck. Ride is great and sacrifices very little when towing as seen in the link provided about the talk.
DirtNasty08 Jun 27, 2011 02:07 AM
1 Attachment(s)
Great wright up made my install a piece of cake!:guns:
gnasty1521 Jun 27, 2011 08:16 AM
Finally, some feedback! I was wondering if anyone ever read these... Glad it worked out for you!
:cheers:
BrutalSierra Jan 2, 2012 08:50 PM
Just put the shackles and removed the block on my truck.
Now the front it 1/2" taller. Guess I'll get some Belltech drop struts and drop an inch.
jessanator Jul 14, 2012 06:10 PM
its kind of a hit and a miss... mine was still higher in the back after shackles and the block, my friends cc came out perfect level
RacinRust Jan 15, 2013 10:03 PM
Got er done ! With your detailed instructions and air, 45 minutes and its 2" lower in the back. Used my Autozone reward card and the shackles were 12 bucks! Thanks for the details. The 7800 Sway bar is next !
gtyler04 Jan 30, 2013 05:23 PM
Very helpful SSGT thanks.
goinbrokez28 Apr 30, 2013 05:07 PM
Just knocked this out in a little over an hour. lowered it down an 1' 1/2 in the rear, will be removing the factory lift block tomorrow to level it up. It already looks 10x better than before. Thanks for the great info!
Choda Sep 7, 2013 10:09 PM
really thinking about doing this to mine, I hate the rear being so much higher.
only negative thing I can think of is launching in 4wd, the front will wanna lift easier with the rear lower right?
AUTOT3K Oct 1, 2013 10:05 PM
you should always torque suspension components in the loaded position because when you torque with everything hanging and then lower it down it'll bind up the bushings and they will tear and wear out a lot faster.
I also coat my bolts with anti-seize so if I ever have to do something later its easy to remove (like when I did my flip kit 2 years after the shackles)
great write up though!
