TECHNICAL WRITE-UPS A place for great instructional threads by members and moderators.
How To: Make your own Adjustable Sway Bar End Links
Old 09-11-2012, 10:37 PM
Ketis's Avatar
Default How To: Make your own Adjustable Sway Bar End Links
I added a rear sway bar on my truck that i got from an escalade, i made a how to post on how to install it and here is how you make your own end links depending on what amount of drop you have.
The stock end links are way too long.
Parts you will need:
2 Sway bar end links
2 Thread couplings
4 Nuts
Tap and Die set
so set up your bar parallel with the ground while the truck is on a level surface
Measure the distance between the bolt holes on the top mount and the sway bar.
This is the number you will be trying to achieve.
cut the middle out of both endlinks so that there is equal space left on each end and cut them a little shorter than the number you will need about 1/8 of an inch on each side (so that you can adjust them shorter if you need to)
Get a caliper to determine the diameter of the shaft so you know what die you will use and which nuts/couplings to get
Thread both ends of the endlink so that they look like this (use plenty of cutting fluid or you will have a hard time)
Then just thread the nuts on first on each end, and thread both ends into the coupling.
Install on the vehicle and adjust as needed.
Tighten the Jam Nuts so nothing turns or is lose
Old 09-11-2012, 10:58 PM
texasglock23's Avatar
nice!
Old 02-17-2013, 05:04 PM
10 Second Truck Club
RS/SS 4.8's Avatar
This is a good idea. Thinkin about adding one to my rcsb.
Old 04-19-2013, 10:31 PM
Chevygearhead84's Avatar
Smart idea and good write up....
Old 04-19-2013, 11:01 PM
TexasSteve's Avatar
What about the chassis side mounts? Did you swap the Escalade pieces over too & were the mounting holes already there or did you have to drill holes?
Old 05-15-2013, 08:55 PM
MASS seller approved
robert85's Avatar
Thanks buddy! I used this write up with my endlinks when I recently added my sway bar. Very easy and affordable.
Old 06-16-2013, 07:33 PM
UBLUZIN03's Avatar
Very cool! What size tap and thread couple did you use?
Old 06-17-2013, 09:43 AM
Ketis's Avatar
i used a 1/2" nc13 die
the couple can be found at ace/HD/lowes etc.
chopperloco
07-10-2016 10:45 PM
Kaldar
07-27-2015 06:42 PM
DONTH8
07-26-2015 06:59 PM
Ketis
07-23-2015 12:37 PM
maxspeed05V
07-19-2015 07:08 PM
Quick Reply: How To: Make your own Adjustable Sway Bar End Links
