Aftermarket seat heaters
I will be adding a set of Katzkin leathers and i wanted to add some seat heaters too. I was wondering which ones people add. I found a universal seat heater set made my Dorman i was thinking about buying. Any other suggestions?
Hunt&Fisherator
Just another use for some AN fittings.... Run some nylon tubing from your radiator, under the floor, into the seats and back out. Use a needle valve to regulate the flow. Barely cracked would give you a nice rump roast... Wide open would burn the buns
Don't forget to top off your coolant
11 Second Hall Moniter
My duramax has aftermarket seat heaters under the factory leather. They weren't working when I bought the truck. I looked at the fuses once, never went any deeper. They still don't work, and I still don't know why. LOL
I have no idea what brand they are.
Ain't I a lot of help?!?
I swapped a harness from an 02 2500 lt into mine with set of avalanche seats, ever thought of adding factory heaters and just putting power and ground to harness?? I know most of the 99-02 ls trucks were prewired but im sure the 04 had something to do with ddm or bcm so may not be easiest, may be something to look at though...
