Replacing radio
Old Jul 8, 2008 | 06:53 PM
southern_chevy's Avatar
Default Replacing radio
I am in bad need of swapping out my stock radio with an after market one, but I have bose. Do I have to have the interface thing to keep my bose or will the regular wiring harness adapter keep it going? I dont care if the buzzer and stuff still works at all I really do not like them. If so where is the best place to get one?
Old Jul 9, 2008 | 11:04 AM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
nah think you gotta have the PAC converter to get it tow work with the factory amp.
Old Jul 10, 2008 | 05:30 PM
If this is on the 04 listed in your sig there is a jumper harness that is behind the radio a/c control head that ties in the bose amp with the factory wiring heading to the rear doors and front doors. If you unplug the harness and use a harness adaptor you bypass the bose and are connected directly to the speaker wiring running to the doors. You will lose the tweeters on the A-pillars though. You can located the plug by following the bose harness up from the center console behind the dash. This plug is snapped to the backside with a tab. The harness runs on the driverside of the center console up and then behind the a/c control panel where it interfaces with the crossdash body harness.
Old Jul 19, 2008 | 02:22 PM
So if I use that harness I can buy the wire harness for a non bose truck and just by pass the bose amp? As far as the tweeters are couldnt I just splice them into the door speaker wires?
Old Jul 19, 2008 | 05:38 PM
timmer1's Avatar
If you do that, make sure you put bass blockers on the tweeters. Unless they are built right into the tweeter, but I doubt it. They don't like to play bass too much.
Old Jul 19, 2008 | 06:18 PM
Ya that wont be to much of a problem I just dont want to buy the box to keep the bose amp when I have another sub and amp for base. Just want to bypass the Bose amp.
Old Jul 20, 2008 | 08:07 AM
timmer1's Avatar
some bass still travels to the highs speakers and 6 1/2's and 6 x 9's can take a little bit of what the deck sends to it, but the tweets aren't supposed to have any.
Old Jul 20, 2008 | 01:51 PM
ya I know that I was talking about the bass blockers are no prob. but does anyone know if I can get a connector that plugs in to the post BOSE amp wiring by the deck?
Old Jul 21, 2008 | 02:55 PM
You just get an adaptor harness for a non-bose standard audio system and it will plug right in.
Old Jul 21, 2008 | 10:23 PM
Thanks man. I went and talked to a local audio guy today and he hooked my up with all the install stuff. So it looks like tomorrow after work it will be going in.
legerwn
56
Nov 15, 2015 10:21 PM
Mr. Chainsaw
Sep 24, 2015 09:45 PM
silver-mod-o
Sep 19, 2015 08:46 PM
97aztecgt
Sep 10, 2015 05:07 PM
