Need help troubleshooting stereo problems - 2009 Sierra
2009 Sierra SLT, came with Bose
Prior to yesterday, I had JVC HU, Swag 6.5s, factory sub and amp, Kicker 8L5 with cheap Dual Amp Yesterday I removed the Kicker 8L5 and cheap amp, replaced with two Kicker 8L7s and a Pioneer 800W amp. I put one under the back seat and the other is in a stealth box under the console. In doing this, I had to remove the factory Bose sub under the console. I retained the factory Bose amp and reconnected the big modular plug that goes to it. The only thing that didn't get connected was the small modular plug that went to the factory Bose sub. Now, a song will start to play, and within 5 seconds it cuts to half volume (all speakers). It's going into some sort of safe/protect mode and I don't know enough about it to troubleshoot it. Any ideas? |
Originally Posted by RICEETER
(Post 5522998)
Prior to yesterday, I had JVC HU, Swag 6.5s, factory sub and amp, Kicker 8L5 with cheap Dual Amp Yesterday I removed the Kicker 8L5 and cheap amp, replaced with two Kicker 8L7s and a Pioneer 800W amp. I put one under the back seat and the other is in a stealth box under the console. In doing this, I had to remove the factory Bose sub under the console. I retained the factory Bose amp and reconnected the big modular plug that goes to it. The only thing that didn't get connected was the small modular plug that went to the factory Bose sub. Now, a song will start to play, and within 5 seconds it cuts to half volume (all speakers). It's going into some sort of safe/protect mode and I don't know enough about it to troubleshoot it. Any ideas? You may have a short in the speaker wiring. Use the balance/fade to see if you can isolate it that way. Or use the diagram to check speaker impedance at the connectors with a DVOM by backprobing the connectors. |
Please, stop moving the camera !!! Video only suggested user to buy a new unit. No help.
192.168.100.1 192.168.1.1 |
| All times are GMT -5. The time now is 11:31 PM. |
