Which LED to use for HVAC/Radio Lights?
Old Oct 11, 2007 | 07:06 PM
agreif's Avatar
Question Which LED to use for HVAC/Radio Lights?
Ok I was able to solder in new radio lights with the regular incandesents from radio shack but now I have the bug and would like to do the LED's. I understand the process to do them with resistors, just am unsure of the bulb choice.
I would like to do blue, but am not sure which LED to go with, more intensity at less of an angle or less intensity at a large angle? These are the ones from superbrightleds. When you guys are doing the HVAC/radio and other dash lights (non-cluster) what angles have you chosen and would you go with something different if you had to do it again?
PN Color bright angle
RL5-B12120 Blue 1200 120°
RL5-B2545 Blue 2500 45°
RL5-B4630 Blue 4600 30°
RL5-B2430 Blue 2400 30°
RL5-B5515 Blue 5500 15°
Thanks guys,
Andrew
__________________
Old Oct 11, 2007 | 11:03 PM
UnrthdxDream's Avatar
if you dont want the look of "hotspots" i would imagine getting a larger angle would help out...
Old Oct 12, 2007 | 06:26 AM
agreif's Avatar
Agreed, just wondering if the 120 is going to be too dim.
Old Oct 12, 2007 | 09:11 AM
Tootall's Avatar
can you take pics of this, I've been wanting to do the same thing
Old Oct 12, 2007 | 09:27 AM
agreif's Avatar
when I do I sure will, just need to get a consensus on which lights seem to work the best for people.
Old Oct 12, 2007 | 11:01 AM
04BlackSilverado's Avatar
I use PLCC SMD LED's.
What to look for is:
120° Viewing angle
Around 500 MCD <--- Very Important
Between 20ma and 30ma of foward current
Between 3 to 4 Foward Volts
https://www.performancetrucks.net/fo...highlight=PLCC
Old Oct 12, 2007 | 11:14 AM
agreif's Avatar
ok, cool. I've seen yours but wasn't sure what angle those are. I think I'll try the 5mm 120 degree spread one. I'll try and order those up and be good to go. Looks like I'm off to pick up some 560 resistors. It looks like if I use the 1200mcd with the 120* viewing angle I'll be putting out pretty much double the output of the current incandescant...might have to try some bigger resistors then (http://led.linear1.org/lumen.wiz). Thanks for help, Steve. I appreciate it!.
Old Oct 14, 2007 | 11:07 AM
1200mcd might be too bright.
I hope it works out. Post up some pics when its done!! keep us up to date.
Old Oct 16, 2007 | 10:07 AM
glassesmalone's Avatar
post some pics sounds like a clean mod when completed
RustyD
May 23, 2016 07:04 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
carid
Oct 1, 2015 09:22 AM
RS/SS 4.8
Sep 18, 2015 11:41 PM
fiatdale
Sep 11, 2015 02:07 PM
