component install help
It's not terribly noticeable to be honest. It does seem like the tweeters are more pronounced than the mids however. With that JL amp with the built in DSP I could time align and EQ each individual speaker. It will give me a lot more flexibility over my current 2 channel setup with the passive crossovers.
If you have time alignment in the radio you could also utilize that and not have to get a processor. This is all if you want to find away around spending more.
You could drop the crossover off the front door speakers and let them play full range and use the crossover on the tweeter only..
Just a thought, might be fun to experiment with if nothing else.
I also bet it would work out really nicely.
You could band aid it by running all the door speakers off of the front or rear channel and amping them (like you have it now) and running the tweeters off the other channel but off the radio. Then you could fade front to rear to adjust your tweeter level.
I currently have a 5 channel amp but I'm only using the front channel and the sub. So I could amp each driver separately, but my HU doesn't have the processing necessary to do it correctly IMO.
11 Second Club
I know Pioneer and Sony have preamp only head units. I bet there's lots more.
I did one click in google and found this expensive bugger: Pioneer Stage 4 DEX-P99RS
Cough, cough, $1200, cough, cough.
